Keep it going,, I bought mine a few weeks ago, Just got started on it a little at a time. ,, had pure hell getting the right wing to line up with the center section, it was crooked, and no where near being correct, no amount of sanding and filing on the tabs or slots would allow it to work. ended up having to knock the rear alignment tab out of the center section, make a new one, install it, line it up and then cut a section of the bottom wing out to hysol the new tab in. Sand the wingtubes of the center section. I sure hope the left wing goes easier.
Would love to see pics of a DLE-61 in it, assuming you are going to try and use a slimline pitts muffler, curious if it will all fit on the sides in the cowl. Im just about sold on the DLE-55 RA I have seen that they fit completely, without cutting out the sides of the cowl..
