What prop is on the model now? Looking at the pitch angle will tell you if it's a clockwise or anticlockwise rotation prop.
If it has no prop then your options for a "pusher" or reverse pitch prop which will turn anticlockwise as seen from behind will be very limited. You'll likely end up having to alter the thrust offset to suit the more common props found in England.
