I finish the battery box install all except the wiring I plan to put in to make it look a little more realistic looking.
Be sure to scratch the paint from the fuel bladder and as it has a slit curve in it you will have to push down and hold as the glue dries.
If you scratch the paint a little too wide , just paint it with a black sharpie.
scratch the paint off the bottom and back of the seat and also the places in the cockpit where they will be joined and I used the Rubberized CA on this. I also put a screw through the bottom as an extra added precaution from vibrations.
Here the canopy are installed
