Fly into the new year with a new Jet Central Turbine. Home of the True Lifetime Warranty and Flat 25 hour Service Charge.
Begining
November 27th through December 31st we will be running the following great deals on our Turbines.
Specials
Super Bee Entry Level Kit 15.5 lbs of Thrust $1985.00 With out ECU Battery,
Here are just a few Jet that are perfect for a Super Bee due to the light weight low fuel consumption and thrust which makes the Super Bee a 70N not a 60N ,
Xcalibur, Boomerang Sprint & Nano, BVM F-86 & other small BVM Jets, FB L-39 1/6.5, Velox, Viper 1.9, SM Xtreme A-10 & other twin Projects.
Rabbit (110) SP 24lbs of thrust $2515.00
Cheetah (150) SP 34lbs of thrust $2875.00
Rhino (200) 45lbs of thrust $3325.00
Mammoth (225) SP 51lbs of thrust $4315.00
With Jet Central Turbines once you buy your turbine you don't have to worry about paying for any in between service or parts. Our Lifetime Warranty Covers every part of your turbine so you don't ever have to worry about paying for a new ECU, Starter Motor or any part for the life of your turbine even in a crash we give you the option of getting a new turbine at a nice discount. Also our Flat Rate Service is just as nice as you don't ever have to worry about how much is it going to cost you when sending in your turbine for your 25hr service. With Jet Central it's always the same $250 plus shipping.
Jet Central Turbines - Small, light weight, more thrust which means more fun.
