Bottom spar is removed for main wheel retract gap.
Use 1/4" and cover with thin CA for strength and fuel-proofing
Epoxy the 1/4" spar bridge with a 3/8" balsa sandwich filler between top and bottom spars
Bottom spar will have to be cut to fit dual main wheels into retract bay and wheels will then bump into (and stop) at top spar
