Originally Posted by
jim p.
Hope you have better luck than I have had with mine. 3-Flights with the stock battery, 1800 Mah ,and with a 2200 Mah. It's a turd and just barely flies. Have played with the Cg from 70 to 87..Nothing helps. Wired up a 8000 4s, 50c tonight. Not impressed at-all right now.
Thanks Jim,
I don't know which ranger you have the 757-4 or 757-3 but people who have issues with their planes, change the motor angle, change the prop to a bigger one, remove the landing gear , get more powerful motor, get autopilot with flight stabilization.
Mine is the 1.4 wingspan version 757-4. Hope you fix whatever is wrong with your ranger.
