Originally Posted by
bRandom
Hi I just got a used Rookie 2 with a VT-90 and with the silver ICS (propane start) and was going to use a A123 9.9V on the starter/pump, but was confused by these 2 statements in the manual. I assume the first statement means I should get a battery with the same voltage, but wanted to verify... Thanks! Should I use a 2-cell lipo or do you recommend another specific battery?
-Use the recommended (supplied) starter motor battery or one of the same voltage.If you decide to use a battery with different voltage, the turbine ECU has to be readjusted at the factory
-The I.C.S. can work with pump battery voltages between 1.2V and 15V in manual start mode, and from 4,8V to 15V in auto start mode.
Brandon
