Yay!
Servos came today. This is the first time I've ordered from RC Japan. I'll do it again for sure, good savings.
I also lined up the elevators and installed the center tube in the fuselage. That was really simple, it fit nice and snug with no sanding required and was perfectly aligned. I did have to make a minor tweak to the front stab tube on the left side to lower the leading edge just slightly. I used the same method as I did on the BiSide (and also on the Agenda post by Ram). I simply took a T-Pin and poked it into the root rib around the CF tube in the left stab, all the way around the tube. This made enough clearance where I could twist the stab to align it. I dripped a small amount of CA on it to hold it in place and then final glued it. Easy to do. Everything else lined up squarely so this was an easy mounting activity.
Steve
