RCU Forums - View Single Post - Top RC Zero from Gator R/C
Old 12-21-2015, 08:30 AM
  #73
Hot Rod Todd
Hot Rod Todd's Avatar
I used some tape, and some measuring to align the gear doors. Make some lines and get the holes where you want them. I started with small holes, then used a tiny rat tailed file to make the holes align perfectly. This is a critical step, so try to take your time and drill them correctly. Some additional spacing work helped to get them to align perfectly with the wing skin. It took a bit of work and time, but I was happy with the result. Much more work than the Top Flite FW-190 I did that comes almost pre-done, but because you are doing it yourself you can get them more perfectly aligned (if you're good)
That's about it for the wings. I'll be adding some details like guns later, but functionally they're done. I'll get started on the fuse next.
