Build an Ashley MM
The engine was removed and some front motor mount supports were added.
Begin by sanding the surface in front of the mount to allow for good glue contact.
Cover the engine mount holes with Vaseline. Spread Vaseline over two screws and attach them in front of the mount.
Cut up some pieces of fiberglass cloth.
Mix about 1/2 ounce of 6-minute epoxy. Add the cloth until thick.
Dab the mixture over the screws and contact the side wall. In about two minutes wet your fingers and form the epoxy in front of the mount.
