Old 12-27-2015, 04:03 PM
  #39
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
flyme2moon, nice start on the panther. I see that it is basically stock, meaning you will probably want to go with a smaller turbine. I upgraded mine in key areas for the extra weight of the added details and higher thrust of my K80. I added spruce spars to the stab, extended the aluminum wing tube out one more rib and added a ply piece to that rib, used spruce for the main spars instead of balsa. I also added strips of carbon fiber to the vertical fin under and up to the stab, about 4 strips on each side. On former F-9 where your CG is marked you will need to add a cross brace. I would also make sure the original builder added the proper washout on the wings, something I always check when I take over another person project. I also cut off the fiberglass intakes and mounted the turbine as far forward as possible, this saves a lot in nose ballast. I have the fiberglass intakes on mine just to give it a clean look when looking at the intake, in reality it does not need the smooth fiberglass intakes at all. Good luck and feel free to post here if you like!
dionysusbacchus is offline
