Originally Posted by
JMCHASE
first I have the Dynaflite instruction booklet. referring to the instillation of the steel shaft in the inboard wings. the instructions call for the inner wings to have a 3.5 degree dihedral...so the metal rod needs the same. how did you approach this did you build both wings first then build in the shaft angle. seems to me if you follow the instructions and build one wing at a time you run the risk of the shaft not fitting perfectly due to the angle in the wing. and how did you build the support for the shaft between the spars.
Ahhhh, understood. Actually, it's no problem, just a bit confusing with the way they described it - and a bit cumbersome. They want you to build the wing and then drill through the ribs to install the joiner tube - there's a much easier way (which is what I do with most of my "big wings": build the wing - LE, TE, top & bottom spars, ribs, bottom sheeting. Install FRONT sheer webs for ribs 1-5 and then simply dig out the area between the spars with a drill or exacto (my method). It doesn't have to be perfect. I actually remove about 95% of the wood in this section. As long as you leave rib-wood connected to the top and bottom spars you're OK. I DO drill out at the joiner rib (where the 2 wings come together) so it's a stable (and decent looking) support for the tube but nowhere else. Then just place the tube in the wing and epoxy in place. I did a quickie drawing:
Rib #1 is the joiner rib, and it's actually angled slightly (forgot to draw that in) - it actually gets drilled. #2-4 get dug out. Kinda like this - the red area below:
The green is the front sheer web. You're digging out ribs 2-4. #5 is untouched. Going back to the top pic, once the tube is in place I filled the entire green area with balsa & epoxy. It's 100% solid.
on page 7 it shows a picture of a rib where you cut out a center section instructions 14 are a bit confusing it says to cut this piece out and glue it to the end of the innermost shear web? that makes no sense.
Yeah, you're looking at step 13 - understood. The rib is cut out to fit it outside those polyhedral braces - you're actually cutting the rib in half, removing that center section entirely. I'm one of those "build it like a tank and it'll never fail" guys. I actually went one better than the instructions. What I did there was NOT install the polyhedral rib until after the inner and outer wings were joined by the braces that fits between the spars, making a single wing (left or right). Then I added an outer ply brace to that, like a sheer web, front and back. THEN I cut and fitted polyhedral rib in place, using epoxy to join them to the structure (spars-webbing, LE, TE). I remember that it took me quite awhile to think this one out too. They could definitely make their thinking a bit clearer in that section.
Gotta tell you, it's kinda fun, going back and re-thinking my thinking back then. There was a lot of "geez, how am I ever going to do this" kind of thinking with this bird. Sure is worth it though.
