Yours is the kit version, stick built, the print out you did was for the ARF, a nice plane for sure but much more weight. Yours will fly fine w/o ailerons, thats the way they came. I modified mine as I built it adding ailerons to about 2/3's on each side about 2 inches deep. Add your servo mounts, "Y" harness and you are good to go! They fly much nicer that way. My advice, fly yours and then make the changes if you like it!
