Project is nearing completion, some minor mods done to set up linkage correctly. Reciever box was in the way so i chopped it up. I lowered the steering servo to chassis level to correct the wonky toe-in syndrom when compressing the front suspension. The chaos steering setup didnt like the mini inferno's front end. Body is mounted with velcro on the back and a screw and lexan on the front. Body sits a tad lower, so i cut a notch for the fuel tank to go through. It rolls pretty freely with the nitro mini inferno diffs and pinions, but im waiting until spring to fire it up and break in the gears. Though i did start it to drive around my kitchen due to my impatience anyway, here are some pictures.
