Old 01-24-2016, 04:21 PM
  #40
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Build an Ashley MM
Some 1/4" wide by pieces of 1/64" plywood were cut into strips.
Slots were cut into the balsa sheets using my slot jig. It is made by placing an exacto blade between pieces of plywood. Parts are held together with a couple screws and nuts.
The plywood strips were placed into the slots.
Some thin CA is used to glue in the strips.
A sanding block was then used to true up the edges and remove any excess hardened CA.
ID:	2143225   Click image for larger version
ID:	2143226   Click image for larger version
ID:	2143227   Click image for larger version
ID:	2143228   Click image for larger version
ID:	2143229   Click image for larger version
ID:	2143230   Click image for larger version
sahartman21 is offline
