Bottom Wing Sheeting
After the wing was sanded to accept the sheeting, I made the 4 wing panels per the instructions. Maybe the wood shrunk after 20 years, but one panel on one side was a little small. Either that or the wing is too big. It really looks symmetrical and measures out ok. I added 5/8" to the front and figured I'd patch any missing areas once it was glued on. One could use another 1/2" to one of the 42" lengths. Maybe the curvature was not accounted for when sheeting materials were picked. Nevertheless, easy to fix. I used pins, wood glue and tacked down with CA. I wetted the wood a bit. The curve over the ribs isn't too bad except for the center front which had to be clamped down and it cracked. This fillet area will likely be sanded off anyway once I fit to fuselage.
The bottom sheeting gets trimmed to the ends of the leading and trailing edges. The top will overhang to create a fairing.
I ran large soda straws as lite weight conduit for the servo wire and I am planning for navigation lights. The Mustang also had "recognition" lights on the right wing. The straws are taped with aluminum duct tape which from experience, sticks well over time. Now's a good time to check wire lengths. All will enter the center of the wing and eventually connect into the fuse.
I'll prep and try building landing gear doors out of fiberglass and CF sheeting. I'll use the lite plywood die cutouts as a guide.
I don't want to seal on the top sheeting till I install the landing gear. They are still out for repair. I called and was promised an expedited look at fixing them.
Reason: error
