Build an Ashley MM
The leading edge (1/4" thick balsa) was attached with Gorilla Glue.
The surface was dampened with a moist paper towel initially. A thin bead of glue was applied and the leading edge was taped in place.
Gorilla Glue foams to fill gaps. There was a little too much foam so it was removed before it dried.
