Build an Ashley MM
About 3/4 ounce of finishing epoxy was mixed.
A small amount was applied to the front of the firewall.
The mount, engine, spacer, and spinner were installed. The spinner was taped onto the nose.
Cotton flocks were added to the remaining finishing epoxy and were mixed. This was applied to the back of the firewall and particularly around the joint.
The alignment was double and triple checked and then the fuselage was set out of the way to dry.
