Next was gluing the vertical (no pic, but pictured in the manual). I contemplated adding blind nuts to the base of the vertical to pull it down tight during gluing, but ended up not doing it because of limited access. This got me thinking, it would be extremely easy to make the vertical removable with a couple tweaks and a pin style rudder hinge.
While that was drying, I installed all the servos. The one thing I recommend is adding a support to the rudder and elevator servo plate because there is quite a bit of flex. You can see the support I added.
