Diodes are polarized. The "bar" on one side of the diode indicates the side that should be closer to the negative (battery) side of the circuit. As mentioned before there is an approximate 0.7 volt drop for each diode you put in series. If you use a voltmeter you may only see 0.59 to 0.60 drop, depending on the diode.
