Those control horns are similar to the ones that I make. I prefer to "notch" the leading edge of horn to fit into the rudder/elevator leading edge. Also, the center section where there is an extension I drill small holes to allow epoxy to seep through. The last thing is to box in the horn center section with either hard wood or hard balsa (usually the horn is installed onto a rib and the "box" is completed by epoxying the wood on the open side of the horn.
Hope this helps,
Ray
