I would just flow a little thin CA in the crack and be done with it. What has happened is the seam has popped in that small area. Wicking thin CA in will re-attach the seaming strip on the inside to the fuse side. I'm pretty sure that fuse is made from polyester so CA will stick really well. In reality, it's a 5 minute fix.
