BAT 64 Lock Out
Just posting for assistance...
I have been using the weatronic 2.4 system since 2009 with no problems whatsoever in jets and large scale birds.
I have received my BAT64 at jetpower messe this year.
Since then I have been testing it in a test model before using the system in a jet model.
Until this weekend the system worked flawlessly. On the last flight the aircraft while flying straight and level went into a vertical nose dive and crashed.
All controls were non responsive and the elevator went to full down on its own. There was no failsafe audio warning (so I doubt the system went into failsafe)
I did not have the SD card this weekend, so no log is available.
The receiver was a micro 10. All servos and receiver recovered rom the crash worked fine, I range tested them and tested the failsafe at the field right after the crash. All seem to operate fine, and the telemetry from the receivers in range test mode seems normal.
I look forward to your thoughts.
