Just looked at the AR636 receiver , The BIND port is labeled (BIND/PRG), and I was interested in Telemetry for Battery Voltage, but did not like that you had to splice into the battery wires to make that Voltage Telemetry connection. Isnt there a T-connector type plug that allows you to connect the Battery and the Voltage Telemetry through a T-connector of some sort. Do you by anychance know of a easier way then splicing?
