Jim,
The two stab tubes of the Nuance are on the stab centerline. Pull one of the stabs out a bit and reference the tubes to zero relative to your table. then the leading edge of the wing should be higher than the trailing edge from the table. According to your numbers, it's probably only a couple of millimeters.
The numbers quoted for triangulation trimming are Bryan's recommended starting point, not necessarily the final triimmed result. Often the final incidence of the wing is a bit higher, like 7 mm.
John
