Originally Posted by
JoeJr1485
Okay so I have the flight computer plus. When looking at the connections, Thro output 1/2, thro input, telem out, eng 1/2 do I plug my throttle output from my CB200 into the thro input into the flight computer then from thro output 1 to my ECU? then connect the telem output from the flight computer to my CB200? I want to make sure I have my connections right.
Gaspar
If you want the GPS data recorded by the FC1 to be viewed later in 3D in Google Earth, you should use the Xicoy GPS. The FC1 can't get the data from other GPS sources.
Gaspar
Thanks Gaspar, I was wondering if you had a chance to see the other post that I added just above the GPS? I want to make sure I have my connections correct when I plug this thing in. I cant wait to use it but trying to figure out if my throttle line from my Receiver plugs into the FC1 Throttle input then from the FC1 eng 1 output back to the ECU to control the throttle?
