Too heavy with nose weight needed.Both would be over powered, the P-100 in mine is too much really, though perfect for real scale flight. I'd go CARF, though both models struggle with availability of Gear!
Rob's example set up exactly as mine with a P-100Rx needed 700g of nose weight...mine has none! I guess the tail construction is the variable
