Originally Posted by
RustyUs
The Mamba Max Pro has a selective BEC output (5v~7.2v). I don't know what the default setting is on the ESC, but check it out.
Update: MMP default BEC setting is 5.5 volts, and I believe you need Castle Link or Feild Link to change the settings.
Do you have a Castle Link?
Yes I have it, and in the Yeti I have it up to 6.5 volts because its running the servo and the lights. I have the Wraith up to 7.0 because I have the high voltage servo and lights on it. You think that is adequate? At 7 its pumping about 440 sq in of torque 480 is the highest at 7.2 or .5 cant remember.
