Originally Posted by
cmp3cantrj
However the two remaining potential causes of uncommanded engine stop namely fuel supply interruption and "falling off the bottom" when returning to idle are also potential symptoms of problems that could make restarting inadvisable.
Not sure what "falling off the bottom" is but can you give your reasoning why it would be inadvisable to restart after a fuel supply interruption (assuming all other parameters mentioned above are met)?
