I read the sticky after posting thinking it wasn't about the 35 my mistake. On this engine the timing can range from 40 to just over 50 no way to get it down to 28 which makes sense to me. I found the CH hall sensors and ordered 2 will they be ok or should I also order the hall from RcXel
Originally Posted by
kmeyers
Technical Writing is a highly developed skill... The manual is wrong.
The ignition was designed for a 28* advance at full throttle and ~ 1 to 4* at idle. C&H helped RcXel with the development of this ignition.
Go to C&H's web site for details on timing. While you are there buy something (like a tester for ignition setup or a new sensor).
Also the second sticky
Rcexl sensor problems goes into detail about some DLE 35's that came with low quality sensors. You may want to read some of this.
