UPDATE:
Made the connection as suggested by Cody at tech support. Seems to operate correctly in terms of switching between modes. HOWEVER, there is still hesitation in the right elevator half. I tried switching the leads, on both the input and output, both with the same result, the hesitation switched to the other half. When I move the elevator stick, both halves move. If I hold, ie, pulling up or holding a banking turn, the hesitating half will all of a sudden go level, up, or down on its own while the other half stays deflected where I have the stick. Even more frustrating, when in heading gain mode, the elevator halves deflect correctly when I move the stick, but turn away from each other when the Alpha 6 is stabilizing. When the nose of the plane goes down, the right side goes up and the left side goes down, like ailerons. Almost like the Alpha 6 acts like a servo reverser in heading gain mode. YES, I MADE SURE THE ELEVATORS WERE PLUGGED INTO THE CORRECT PORTS, lol!
I guess I will have to wait for the interface cable as Andy suggested and hope I don't just have a defective unit...
