Originally Posted by
George62
We got the USB interface cable and got the data for the last 51min as the manual claims. It seems there was no problem with temperature or PW - everything just went down suddenly. I used the software to make a graph and enclose it for your evaluation along with the data in numbers.
This log looks to me like the result of a typical flameout caused by a bubble.
As the flame dies the rpm plunges while the ecu tries to keep it up by pumping more fuel. Once the rpm reaches the minimum limit, the ecu gives up and shuts off the fuel supply.
As said before, I think you need to take a hard look at your fuel system and check for leaks.
