Futaba 14SG Slave Channel Is Moving Asymectrical to Master Channel
Hello, I am new to this group. I am having issues with a mix. I have a Futaba 14SG have created a mix with the rudder as the master and aux 1 as the slave. Aux 1 is for a separate nose gear servo. When the gear is down the nose gear servo is active and inactive when up, all that works. However, when I move the rudder stick right I get full deflection of the Aux 1 servo. When I move the stick left, it only moves 2/3rds of full deflection. The graph in the mix setup confirms what is happening. The rudder and aux 1 is not in any other mix. Any idea why I cannot get full deflection in both directions?
