Your suggestion to use the servo monitor led me to the culprit. The dual rate function on the rudder did not have symmetrical settings so the rudder moved greater in right direction and less in the left direction. The mix was faithfully doing it's job. Thank you very much! You saved me from a lot of frustration.
