Good morning everyone,
I am having a problem in which I can not figure what I may be doing wrong.
I Installed my Cortex Pro via the cable loom to my Futaba R6014HS Rx, no problems .
Teaching the Input signal, no problems.
During the setup however, I am getting all the way to "Elevator neutral Rudder right and hold" , here I get an immediate red light on the cortex pro upon selecting full right rudder. It looks like a short red flash, followed by a longer red flash in a repeating sequence.
I have tried the setup a few times. I as well have removed and plugged in all the connections again, eliminating a loose connection as a problem.
I have run the jet without any Cortex Pro, all connection directly to the Rx, everything works perfect.
So I am not sure where I am going wrong.
I appreciate your experience.
Equipment:
Jet is an Xcalibur Plus
2 AIL servos Rx channels 1 and 2
2 ELV servos Rx channels 3 and 4
2 RUD servos Rx channels 5 and 6
Cortex Pro AUX input channel 7
Tx Futaba 18SZ
Rx Futaba R6014HS
Rx Batt two LiFe Hobbico packs.
All Futaba digital servos
Thanks again
