Hi ...big thanks...thought as much with the fins.
The socket info..big thanks.
Re the stickers...you still have your contact in Germany..if you are okay can you share...if not that is cool.
Cheers
Originally Posted by
Airforce7
1) I glued mine on recently with hot glue. I didn't bother with the tape, it doesn't stick well anyway. I found a blue marker and applied it to the edge all around. BTW I glued the fins straight down at the edge instead of at an angle. There just for looks IMO.
2) 5mm ball driver for the wings. 2.5mm for the vertical stabilizer. Both not very long. For the socket heads in the back for the exhaust nozzle you will need to get an extra long extension to reach them when you install/uninstall the nozzle.
3) No they didn't. But I did put the Chinese demo markings on mine recently. I got them from tailor made decals in Germany.
