It might be worth using the X4 on another battery that you have successfully charged previously just to confirm that the charger is responding as you would expect. Zeeb makes a very good point that may well explain the issue. If you have a volt meter check the polarity on the charging plug before connecting and ensure positive goes to positive when charging.
