I don't believe so. I believe the molded canopy will fit up through the bottom. It may be required for the side rear windows. And if I install the Malcom it would require some mods I'm sure. Still undecided on how I will have the canopy function. The standard has side access and the Malcom would slide back over the turtle deck. It will take some thought to get it all correct. Vic, chime in if you can.
