Fuel octane is related to compression ratio. The higher the compression ratio the higher the octane. If the fuel is E10 or not is a different issue but I prefer Non-E and we have 92 octane here which is designed to be used on 10:1 compression ratio engines.
Then the oil ratio is the next issue...
