been a bit slow of late. Leading edge laminations to outer panels are done. Centre section and one outer panel sanded ready for joining and sanding. Will sand the other tomorrow. Going to make up a couple of dihedral braces for the LE & TE at the gull join to distribute the loads outwards from the joint in that area.
Once those are made and I have done a trial fit I will epoxy the panels to the centre section and epoxy the dihedral braces in place.
Time to start making the balsa skins too.
cheers
P
