For the discussion of FS cowl thickness/size. I just measured with a digital caliper both the FS and original. The plastic one is about 0.033in thick and the FS ranges from 0.025-0.035 around the edge of the perimeter (thinner on top and thicker on the sides). It has an extra layer of fiberglass around the inside perimeter, so it is a little stiffer. Both fit inside each other identically. The FS has a very slightly wider radius on top. Fitted end to end the FS is wider by about half the thickness of the material. Extremely close.
