Originally Posted by
Mpizpilot
Did you guys use the stock hardware? The pushrods look like garbage to me, too small the threads are not cut deep enough. I've had Clevis's pull off because of this issue.
Also, mine didn't come with the metal brackets for mounting servos, instead just the standard wood blocks. I wonder why.
I used much of the stock hardware, although I could see the flap linkage pulling loose if the flaps were dropped at higher speed. That is another reason I chose to use the internal linkage, no mods are needed and it's a stronger set up, pushing is better than pulling.
You need the aluminum servo brackets, unless they changed the internal wing structure, I'm guessing they forgot to include them in your kit.
This is one of my aileron servos, does your wing have the ply tabs in the servo bays? If so you need the brackets, you could make them, I have many in my parts bin left over from other projects.
