Originally Posted by
DCGayhart
You are correct but I have not tried to access the CB200 via the device explorer thru the Cortex Pro. Earlier threads lead me to believe this is not yet possible. If this is true you will need to configure the CB200 prior to connecting the Cortex Pro in series. I'm going out of town for a couple of weeks and will try it when I return.
If you want to use a CB200 with cortex pro through ExBus connections, one of the receivers needs to be an REX receiver .
In that case you have to change the ext port of the CB200 as "Jetibox" and then connect the ext port of the CB200 to either E1 or E2 of the REX receiver... The REX receiver will be primary and the secondary receiver can be any other RX (usually R3)
David
