i like building mine if your up for the challeng - its maybe NOT for novices / i dont know. i built a .46 rv4 by great planes first. the hard part with the bsb is waterproofing the tunnels and using 150 dollars worth of epoxy... it is under appreciated because this is dumass best airboat and it is better with 4 stroke motors turning 3 blade props. however dumas should have made something for the speed demons looking for nonscale type performance.
passing 30mph out of the box needs a totaly different hull......or a smart builder. you could get flat bottomed dumas airboats that are nearly the same size as the bsb. its just a boat... pick one and face reality head on.
