RCU Forums - View Single Post - NZ 30549 - Early Construction M41's
Thread
02-02-2017, 06:40 PM
2
afv aficionado
GLACIS
2
[SUP]
nd
[/SUP]
most prominent feature isthe 2 pairs of horseshoes on the glacis – yep, horseshoes (betraying it’sCavalry roots). –
The ‘horseshoes' are actually splashguards – 1 pair per side – -
for the hull penetrations through which theheadlight wires enter the vehicle. The drawing in the Hunnicutt book showstwinned headlights – white lights & IR – although the original vehiclesonly had white lights – The Ordnance Drawing in Doyle’s book also showsthis –
However, when the vehicles weresubsequently modified with the later style headlights (twinned with IR), thesewere mounted on brackets above &behind the horseshoes. –
On the later vehicles, a single largesplash guard per side was used, on top of which the headlights where placed,offering better protection to the lights wiring. –
ENGINE GRILLE HATCHES
Not quite as prominent, but definitely a feature, the earlyconstruction M41’s engine grille doors are different from the later vehicles,which have 3 grille doors per side, most noticeable from ground level due tothe 3 hinges & stops along the top of the hull. –
The early vehicles have more grille doors – 5 on the leftside & 6 on the right, again, the row of 5 hinges & stops on the leftside & 6 hinges & stops on the right side are quite noticeable. –
- The design of the grilles themselvesis also different, the early grilles have an extra rib running fore/aft throughthe centre of the grille.
The drawing in the Hunnicutt book got these partially right,though only 5 hinges & stops on the RHS –
Pt 3 follows
Mal
Reply
Like
afv aficionado
View Public Profile
Send a private message to afv aficionado
Visit afv aficionado's homepage!
Find More Posts by afv aficionado
View iTrader Profile
