Batteries dying 2x as fast on new charger...
I just got the Tenergy TB6AC charger and when I charge my Blade Nanos batteries on that vs the little usb charger that came with the nano they die in under 4 mins just hovering vs 8 mins when I charge on the USB charger that came with the Nano. I have the Tenergy set up as follows: 3.7 volt lipo, .2amp, 220 mah, input power low cut-off 10.0 v, lipo/lilo/life chk time 60min, temp cut off 80c, safety timer 120min, capacity cutoff 220mah (which is what the battery is) I would really appreciate someone's help because across all the forums I have asked questions on I have not received one single answer on any of them which is kinda discouraging.
