Thanks guys... made the changes and all is working as it should. I believe the culprit was the "Thro-Low" mode. I swap my digital trims around so I can trim AIL/ELE with my left hand on the lefty hand side of the TX. When making the changes I didn't change the modes. Wayne, I like your idea of the Idle/Kill switch...might use it! BTW where do you fly? I see you're in MA...Chris
