Slow charge is NOT the problem. Slow charge OUTSIDE of the tx is.
Do you use a JR connector on that fuel pump battery? No, it's futaba/hitec.
Hong Kong sells male/female connectors 20/package. I need one.
I'll just use the wart to (slow) charge it in the tx and do the (slow) discharge via normal usage of the tx. No cycling possible (per mfg for "forming").
Thanks for your input.
