Juan,
Thank you again for your assistance.
I think the best thing to do will be to buy both a 3 blade 24x12 and the 5 blade 23 x 14 and compare rpm and temperatures on ground and in the air. I fly Jeti radio, so I can have full telemetry and even add an optical RPM sensor to the nose to measure prop RPM if needed.
Do you know when the JetCentral Turboprop will switch from the old Xicoy ECU and pump/valves to the new SE electronics and turbine?
I believe that you are not going to use the SP Powerpack on the Turboprop and just go right to SE.
Regards
Lewis
