Originally Posted by
scottkieper
ron this is my mounting. all mounts and plate came with your plane, it came out great with the engine cowl.
Scott-- Your setup is beautiful and clean. Is that a 100cc gas engine you have bolted on? I will be powering my Cessna with an OS-320 Pegasus, which is a 53cc glow engine. I want to build plates with shelves to keep 5 batteries up front which is why I have been exploring wood assembly kits for the engine box. Underneath or in front of the engine box, I'd like to build pocket for a servo that will adjust the engines needle valve for fuel/air mixture going into the carb.
